ricer68
- Mar 23, 2016
- Wabash Indiana
- 2007 Yamaha Apex GT
- North East Indiana
Was doing my end of season servicing and broke a spark plug off in the head. First 3 came out without any problems. The 4th one popped hard and came out with everything but the threads. The electrode came out but all the threads are still in the head. Any suggestions? How bad is it to pull the heads on these?
Snorunner
- Jul 17, 2018
- Deerwood
- 2016 Vector XTX
2017 Vector XTX
2001 Arctic Cat
Do not know if it will work. But there is a tool to remove broken plugs from 2004 and up Ford engines. If you try to remove what’s left without pulling the head you will want that cylinder to be at top dead center on the compression stroke. Valves closed. So you can blow any shavings out. Otherwise the safest bet is to pull the head. Worst part my guess is the timing chain alignment.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Its a ton of work to remove the head, you're pretty much disassembling the entire engine bay. Plan on at least 10 hrs to remove it and probably 6-8 to get it back on. Watch the chains, timing, etc on reassembly.
I would try every other option to remove the plug before pulling head. Is there a hole in it? If so a large extractor could work. Good luck ...crappy deal! Remember to use anti-seize on reassembly.
ricer68
- Mar 23, 2016
- Wabash Indiana
Well no joy...... easy out is in there now. Taking to dealer tomorrow. Guess will be a good time to run the valves while it’s apart. 8500 miles on her so far.
kinger
- Jan 17, 2005
- Clear Lake, IA
You broke the ez-out bit in the head too? Jeeze that thing is really stuck in there!
