Tyloooor
https://m.facebook.com/ddracingllc/?ref=content_filter Hope this is a cat thing and not yamaha
Post the facts, not the link. Not everyone can read that Facebook post.
Snake
- Mar 3, 2016
- Maine
- 2017 Sidewinder XTX 137 LE
**sj**
my clutch came off and went on fine..probably the team clutch (assuming this is a 17' right?)
Tyloooor
Yes sorry Mr sled...seems like it's team issue
machzrobbie
The Yamaha clutch is machined properly so this won't happen = lots of clearance. I had a cat 7000 last year that I worked on that had the same issue with the team primary. It was fine until the clutch was taken off and re torqued on - then it rubbed. The team clutch is very tight to the motor.
**sj**
Could the torque sequence and ft lbs be off considering it's a Yamaha taper?
