yamadooman
- Jan 16, 2005
- New Prague, MN
- 2023 SRX
this has probably been asked a hundred times, but is anybody running the Dalton QAY-70 wts on their stock Sidewinder? If so, are you running them empty, or do you have to load them with a little weight? Thanks in advance
Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
I was testing this yesterday. My setup is stock with a muffler only. Dalton black and green primary w glide washers, Dalton orange secondary wrapped to 70, 33/35 helix. I definitely needed to add some weight, have the 1" in there now, worked my way up from empty.
Sent from my SM-G955U using Tapatalk
yamadooman
- Jan 16, 2005
- New Prague, MN
- 2023 SRX
Thanks for the response, I will be running all stock, so might be slightly different. Just an FYI. The directions say not to run a 1" in there alone
Soupy
- Jan 10, 2017
- West Michigan
I don't have it bottomed out
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
That is with bl/green.....
But with all stock, I would go with the dalton 66g.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
I have a set if needed
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
You got 66g?I have a set if needed
Anyone running a stocker, I would grab these from SJ.
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
going with 74grams on
I have similar set up with TPI springs instead. I will be running 74 grams on Dalton QAY-70 per Ben's suggestion on PT, but given my weight ride style I am sure to be adjusting
- 15K
