Lantz
- Jan 20, 2014
Need some guidance as to correct the darting or hunting on my 2014 Viper LTX, Placed shims under rear of the rubbers for the ski mounts. Did not have a chance to try them out yet.
09nytro
Well try that first
If that doesn't work then I read that putting woodys slim Jim's on helps a lot !
Yamacat21
Slim Jim's are the only way to go!09nytro said:Well try that first
farmerschiferl
- Dec 28, 2010
- Hewitt,WI 54441
- 2017 Yamaha Sidewinder BTX-LE
- Hewitt, WI
check the toe, should be 1/8th out from center
apexhank
- Mar 5, 2011
- HUDSON FALLS AND BIG MOOSE LAKE, NY
- 2021 SIDEWINDER LTX GT (soon)!
2019 SIDEWNDER LTX DX 6000 miles
2018 VIPER LTX DX 2200 miles
2014 VIPER LTX DX 8000 + miles
2014 BENNINGTON 22 ft. PONTOON BOAT/ 90 HP Yamaha
Darting
I've been running 6" Dually Stud-Boys for 10 years. The stock 4" carbides that come on the sled are junk. I ran them for 50 miles, took them off and thru them away. Major darting with the stock ones. Once I replaced with the 6" dually, problem went away. I tried spacers under the ski bumpers on RX-1 and 06 Apex. The duallys make all the difference!
Apex Hank
Apex Hank
stook
I agree dually carbides
X2 they work awesome.Yamacat21 said:Slim Jim's are the only way to go!09nytro said:Well try that first
Studroes144
6" studboy deuce bars here too. No darting whatsoever. Best investment yet on the viper!
fxnytroxtx
Guest
Does it push a lot with the duallys?
Studroes144
I notice very little pushing..only time I experience it is if I'm riding really fast but a little body English takes care of that
RXVIPER
- Mar 4, 2010
- Shelburne ,Ont
- 2014 SR Viper LTX
2003 RX-1
Woodsy slim Jim 6" totally different ride. Worth every penny.
Rxviper said:Woodsy slim Jim 6" totally different ride. Worth every penny.
Right on Changed the sled completely.... I then added a Curve Ski with Slim Jims... now I have a slot car that holds its line in deeper trail snow as well.
Would going from 6" to 9" deuce bars increase or decrease push?
Studroes144
If u already have the 6 inch I'd try adjusting limiter straps first. Tighten them up 1 hole and see how you like that. Mights well try the easy free stuff first before buying new carbides.
