40TH FX NYTRO
- Mar 30, 2010
- Renfrew,Ontario
- 2014 SR VIPER LTX SE Blue and White
Looking for a DC outlet for my 08 FX NYTRO RTX but I don't really want to pay the $75.00 for one from yamaha.
Brad
Brad
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
The adaptor or the whole unit?40TH FX NYTRO said:Looking for a DC outlet for my 08 FX NYTRO RTX but I don't really want to pay the $75.00 for one from yamaha.
Brad
Royal sells the adaptors and I am sure a local communications or the like type store/shop should have the outlets?
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
If you take a look in the "umbrella" behind the headlight you will find a white connector with 6 red wires and a jumper connecting these wires. That connector will provide you +12V when the ignition is on. You can use that, and a wire from your battery to install a relay with power to whatever you want.
traverse tzeits
there is on listed here in the classifieds http://www.ty4stroke.com/viewtopic.php?t=92574
Eggman
I know that artic cat has one that you can get for $12.00. The only drawback is that you will have to hard wire it. I think that the yamaha one will have a harness that you can just plug in, which would be nice. I also know that the yamaha one will be of better quality.
yox185
Eggman said:I think that the yamaha one will have a harness that you can just plug in, which would be nice.
The 08's don't have a plug. It has to be hard wired.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I just installed one on my 08. I found a used OEM outlet on ebay and wired it into the fuse box. I cut the connector off and replaced it with a two wire connector that I picked up at Radio Shack. The fuse box has a empty location that has power on one side when the key is on but needs a insert added to the other side to except a mini fuse. I found inserts at a local auto parts store but had to file a little bit off to make it fit into the box. It's a little more work doing it this way but it's done properly.
