DDMtuning HID
you divid voltage by wattage. 55 watt bulb divided by 12 volts = 4.5 amps per stock bulbs. the 35 watt ddmtunning ballasts draws 6 amps during warm up but once the bulb is warm it only draws 3.4 amps per ballasts. you do save a amp per bulb but you gain 3 times the light output.
mullisha nytro said:
thanks daranello, whats the deal with the hid harness? needed correct?
no you dont need the harness. just pick either the 35 or 55. the h4 bulb and your color (recommend 4500, 5000) but if you want different color bulbs the higher the number the blue'er the light the lower the number the more amber the light is. everything else grizztracks has a post about the wiring for the ddm lighting system.
Thanks, grizztracks pmd me with everything. Def a lot cheaper than sled start :)
