snopro442
- Dec 10, 2007
- neenah wi.
- mod 08 nytro, 2-2007 phazers and a 2010 sno pro 500 speedwerx exterminator. new 2014 nytro for towing the snowcoach. 2015 Viper mpi turbo
I had the Viper running about 4 weeks ago now go to fire it up and it dead. Battery reads 1.01 Volts. What should I be looking at? key was left on but the kill switch was off. Does the roll over valve drain power while sitting? Thanks for any help you may have to offer.
mysledblows
- Jan 23, 2007
- Central MN
- Sidewinder, mcx phazer, phazer, apex
- Jenkins, MN
My experience with the 4 stroke sleds has been key on and kill switch off equals a dead battery. Something doesn't shut off all the way with just the kill switch.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
I run the trickle charger. for the battery but also for the starter. A lot of starter failures seem to happen during the off season. I'm not chancing starting with a low battery.
Put a good slow charge on your battery. Try leaving the key off.
Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
Yes the key needs to be off. On Viper/7000's if you shut it down with the kill switch but leave the key on the gauge will power down. However there is still a power relay in the sled that is being energized. This relay draws about 15-20 milliamps and will drain the battery over time.
With the key off everything is powered down including the relay.
To answer your question about the roll over valve, it does not draw power when the key is off or if the sled is shut down with just the kill switch.
It is worth noting that if you use the ROV tether cord to shut the sled down and leave the key on. The ROV will be on and after approx 2 hours the ROVCM will go in to battery voltage monitoring mode and once the battery voltage reaches approx 12.2 volts the ROVCM will shut down the roll over valve and the sled's power relay as well.
Bill
Bill
snopro442
- Dec 10, 2007
- neenah wi.
Thanks for all of the info, I did order a new Earth X battery for the sled and can someone tell me if I can use the same trickle charger as the stock battery? Thanks again for all the help.
I bought my 15 at the end of the 15 season and last year even though I had it on trickle charge on and all summer it went bad same on my 14 the year before first rude out in the cold no start
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
That seems unacceptable. Iv had good luck so far with my sled.I bought my 15 at the end of the 15 season and last year even though I had it on trickle charge on and all summer it went bad same on my 14 the year before first rude out in the cold no start
The apex I had before this had the original battery at 20000 Kms.
It is but 2 bad cells in it. The 14 has GPS tracking device in it but goes to sleep after 30 mins so should not have ruined battery either
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Maybe you should use the gps and find out where the hell its at. Jk. Hope all is wellIt is but 2 bad cells in it. The 14 has GPS tracking device in it but goes to sleep after 30 mins so should not have ruined battery either
I tried but the battery is out of it
By the way Bleedyamaha pray for snow here I just wrote an offer on 35 acres with a lake 15 min n of Coon Rapids building a grass/snow drag strip and ice drags on the lake and public trail runs next to property. Has pole barn and other barns for shops and a Western bar in the basement of the barn
