Decals peeling
Carla 123
Manitoba
Canada
2015 viper xtx boosted
17 zr9000 precision stage 3
Went to clean the excessive belt dust from the 8jp belt and noticed the gytr decal on the bottom of the belly pan peeling.checked other side and same #*$&@ .wtf Yamaha. Dealer says not covered so out came the hair dryer and removed the decals on both sides.fit and finish on this sled is crap.sorry for venting but I think a 15 k sled should be better quality.
I found that the right side decal was pealing on mine. It's near the exhaust exit so figured it was probably the heat. Trimmed it back to where it was solidly attached and you can't notice it. Other side seems better but might trim it back as preemptive measure.
Looks better without those decals now that I removed them especially that yamalube sticker.probably good for a couple more mph now with the less weight
Cleaned belt dust off mine yesterday, and same thing. Decal starting to peel off. Wasn’t real happy.
Muffler side?
I have a wrap on and it's doing the same thing. I'm planning to put some added insulation on and re-apply adhesive but likely will have to cut it back.
