MtN_Rx1er
hi all, sorry for the postings here, got my clutch weights in so i can install them tomorow on the 04 rx1 mountain. i am doing as u all know Sled dogs clutch setup for my elevation of 600m (1900ft)that has the specs for his mod as follows:
The Primary spring in my sled is a Y-S-Y and the weights are 8FA-17605-10-00 with both rivets installed.
Now,i have the 8fa-17605-10-00 weights with both inner and outer rivets part number 90261-06033-00
i was asked if i needed the inner/outer rivets with a hole in it and i didnt have a clue,as it wasnt specific in the mod page if the 17.2 steels had to have holes or just be solids. i got the weights and noticed they dont have holes, now is this an issue? i seen in the spec sheet (05 warrior) it calls for both inner outer 17.2 with the hole, but i dont think these are. i took a pic of my weights, the TOP 2 are mine and the bottom one looks like what i think might be one with the hole in that i found on the net,now do i have to take these to the dealer and get the inner/outer re riveted or will it be ok? what does the hole even do?
