Nik Schwartz
- Jan 12, 2015
- Pulaksi WI
- 2014 Yamaha Viper LTX
no it didn't, just all the sudden fell right outCrazy pics. I have a buddy with a 7000 Cat with about 3500km's and it did almost the same thing. In Cochrane this December the bottom of the exhaust rotted out and melted the side cowl, the heat also slowly melted the oil line causing oil to spray everywhere. The day it happened was -30 so he said it was tough to notice excess heat along that side of the sled. They just made it back to the trailer, Could have been way worse if it bled out all the oil.
Question - did it give you much warning before it failed completely?
MS
Yamacat711
- Oct 20, 2014
- ZR7000 Ltd
MS
Like Sevey said my exhaust completely let go but it was the stock exhaust. Thinking of getting the sandale system, I've heard really good things about it.
Curtis Chambers
- Nov 19, 2014
- 2015 SRViper R-tx-Le
Crap ones getting put on now with header and clutch kit. Should they not be selling them
Curtis Chambers
- Nov 19, 2014
Talked to performance shop today they have had recall and new ones out already bracket added.
larrypolaris
Looks like I have the beginnings of a small crack. 800 miles on the can.
I purchased it March or April of last year.
I used a mirror to take a pic of the bottom of the can.
Curtis Chambers
- Nov 19, 2014
Absolutely no increase at all just sound and access to chain case adjuster.that includes header.
12pointer
- Nov 24, 2012
- OHIO
- 2015 Viper LTX SE blue and white-Ulmer clutching, 8dn belt, MBRP trail can, J&T 4th wheel kit, Shaper bars,
is the cracking issue only on the older versions? or is happening to the new stainless versions also. Mine is the new stainless version.
Nik Schwartz
- Jan 12, 2015
- Pulaksi WI
older versions
nherbst454
- Feb 25, 2014
- Woodbury, MN
- 2014 SR Viper XTX-SE
Mine is an older version but it does have gussets welded to support the inlet pipe, are there gussets to support the outlet on the new version?
Nik Schwartz
- Jan 12, 2015
- Pulaksi WI
yes there are gussets on the bottom. can you see cracking on the bottom pipe yet?
jlevandoski
- Dec 11, 2014
- Connecticut
- 2014 Yamaha SR Viper XTX SE
I'm looking to buy the MBRP header and Trail Can for my SR Viper. But in Maine, you can't modify the exhaust to be louder than originally designed. Have you guys noticed this setup being louder than stock (or at least noticeably louder than stock)?
1tp
- Feb 2, 2014
- Central Wisconsin
- 2015 Viper R-TX LE Clutched and Canned
2014 Viper L-TX SE Clutched
Under full throttle yes. Otherwise not much of a difference. BTW, I have both the gusseted and non-gusseted cans and think the gusseted can is quieter.
