jeff_yam
- Oct 6, 2010
- Quebec
- 2016 Viper LTX-LE
There is my setup for the next season, anyone know if this setup will be efficient at mid range and top speed? I'm lookink for advices...
2016 LTX-LE
-Stingray airbox mod
-MBRP trail can
-COTC with GWG primary spring + 2x 1mm glide washers + 8FP weights with 4.5g rivet on tip
-Dalton 46/40 Helix with machined spring pocket
-Pink secondary spring
-8DN belt (with 1x 1mm washers under each of the 3 bolts)
-24/50 gearing (I think about changing for 21/41)
-Dupont slides (seem to have less friction than original slides)
2016 LTX-LE
-MBRP trail can
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
Is that all you have to do to run the 8DN belt, is put washers under the 3 bolts?
jeff_yam
- Oct 6, 2010
- Quebec
- 2016 Viper LTX-LE
YesIs that all you have to do to run the 8DN belt, is put washers under the 3 bolts?
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
Thanks bud!
09nytro
There's more to it thAn just the three bolts to do it properly... But you can do it that way ...Is that all you have to do to run the 8DN belt, is put washers under the 3 bolts?
bleedyamaha
- Sep 28, 2013
- Northern Iowa
That's my set up I also have extra wheels and studs. I switched out my gears to the 21/41 and picked up 3/4 mph. Midrange is good. I drag raced a 800 etecs from a stop and we were dead even till 85 mph. We had to slow down.. Very happy with this set up. Love my sled but I am going to try and sell it to buy the new Sidewinder.There is my setup for the next season, anyone know if this setup will be efficient at mid range and top speed? I'm lookink for advices...
2016 LTX-LE
-MBRP trail can
- 236K
