Difference between PC III/Ignition Module
Yamahammer485
West of PG, BC, Canada
Hey all
Did a few searches on this and came up with nothing.
Just wondering what the actual difference between these two are.
I know that you need to run the PC III in order to use the ignition module, but thats preety much it, what does each one do?
The PCIII is for fuel adjustments only. The ignition module when hooked in with the PCIII allows for ignition adjustments +/- 10 degrees anywhere in the map. You must use the PCIII in order to use the Ignition Module.
