What is difference in a 07 phazer gt and a07phazer gt thanks
Ruggybuggy
- Sep 1, 2013
- Kenora, NWOnt, Canada
- 2007 Phazer FX 144
Nothing, they are exactly the same.
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
Wind deflectors I thought. FX not have them.
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
he is asking about a gt vs a gt?? if he does mean gt vs fx the shocks are different all the way around front and rear..the fx has an 18t top gear as the gt has a 20t. grips and handle bars are different, windshield is different and as Mr. walters said wind deflectors..
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
RIGIDONE said:he is asking about a gt vs a gt?? if he does mean gt vs fx the shocks are different all the way around front and rear..the fx has an 18t top gear as the gt has a 20t. grips and handle bars are different, windshield is different and as Mr. walters said wind deflectors..
I think the torsion springs were different too. And the sway bar was different.
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
x2 on the sway bar, dont know about the torsion springs..
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
Here are a few things that I remember from when we pre-ordered in 2006
2007 Phazer GT
1" Hacksaw track
Tall windshield
KYB HPG non-clicker shocks
Straight handlebars
Proactive Torsion Spring rear skid
Swaybar Standard
2007 Phazer FX
1" Ripsaw Track
Short Windshield
GYTR HPG Piggyback Clicker shocks
Hooked Handlebars
Proactive CK rear Skid
Swaybar Standard
2007 Phazer Standard
1" Hacksaw track
No Windshield included
Gas Cell Hydraulic shocks
No Reverse
Straight Handlebars
Swaybar Standard
Gearing as mentioned above and limiter strap and Swaybar setup were different, but could be changed.
2007 Phazer GT
1" Hacksaw track
Tall windshield
Straight handlebars
Swaybar Standard
2007 Phazer FX
1" Ripsaw Track
Short Windshield
Hooked Handlebars
Swaybar Standard
1" Hacksaw track
No Reverse
Straight Handlebars
Swaybar Standard
Ruggybuggy
- Sep 1, 2013
What's the difference between the Proactive CK rear Skid and the Proactive Torsion Spring rear skid?
Also if the GT runs the 20 tooth gear is the top speed higher?
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
[quote="Ruggybuggy"Also if the GT runs the 20 tooth gear is the top speed higher?[/quote]
In theory it should be a little faster but I have had both a 18t and 20t in my GT and the top end is about the the same. The 18t accelerates quite a but quicker.
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
That's the suspension from the Nytro. Must be a typo or something.Ruggybuggy said:What's the difference between the Proactive CK rear Skid and the Proactive Torsion Spring rear skid?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
The GT's sway bar is connected to the A-arms using plastic blocks and are adjustable. The FX uses end links and are non-adjustable.
I do believe that '08+, all Phazers have reverse.
biffdotorg
- Dec 2, 2008
- www.biff.org
- www.biff.org
Phazer FX still has the coupler block on the Sway bar. My 07 manual shows how you can move it to change stiffness.
Phazer standard has never come with reverse standard, but it was listed as an option on future years beyond 2008. 2009 was the first year Yamaha listed the option in the Phazer Standard Specs.
The Phazer FX's Proactive CK was replaced with the Dual Shock CK in the RTX in 2008 to the current model. This is according to the Yamaha-motor specifications online. I think it had more to do with naming after the issues the 2007 skid had.
