snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
just wondering if there are any changes between the 2012-2015 apex xtx ? Thanks
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
2014 and newer came with Tuner skis and Dupont slides from the factory. Colors and graphics are about the only other differences that come to mind.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Is skid frame wheel placement the only difference between the 2011 and 2012?
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
From what I remember, yes.
20/80
- Mar 25, 2010
- Nova Scotia
- 2016 APEX LE XTX
My 2016 apex xtx did not come with Dupont slides from the factory.2014 and newer came with Tuner skis and Dupont slides from the factory. Colors and graphics are about the only other differences that come to mind.
yamahabuyer
- Mar 4, 2010
- Greenwood, WI
- srviper and apex
- greenwood wi
How did the wheel placement change from 11 to 12? I have an 11, any way i could move my wheels to be like a 12?
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
That is correct, Singleshot suspensions didnt come with them. So 14-15 did when they used the 128 Monoshock and 144 CK suspensions.
the 11 mounts are like the phazer ones where the mount and the spring end are part of the wheel mount. from what i remeber on my 2012-15 skid, they separated the spring and wheel mount to move the wheel further ahead on the rail. did not really affect slider wear as both skids wore at the tip-up at the rear the same.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I have no wear at the tip up on mine but yes the spring mount is all in one with the wheel mount on the 11 and they are separate on the 12 also the spindle location on the ski is different as well. 2012 and up skis are different.
whitedust1
- Jan 10, 2008
- Waterford ,WI
- 2012 Apex XTX
Better off with single keel skis and aggressive snow trackers all my buds ditched the tuners. My bud has both 11 and 12 Apex xtx one red one black hyfax wear about the same on DuPonts.
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
I do believe there was a ski change from 11 to 12 as well that changed the placement of the spindle in the ski. In otherwords it was molded with the saddle further forward or back. Not sure which way.From what I remember, yes.
But yes, as stated above, they actually seem to perform better than a tuner with the use of Snow Trackers or Dooleys
i think 12 had the tuners as i know my 11 did not but it was an updated/new ski.
biffdotorg
- Dec 2, 2008
- www.biff.org
- www.biff.org
Sorry no, they were the single keel ski.i think 12 had the tuners as i know my 11 did not but it was an updated/new ski.
Firedawg1998
- Oct 17, 2018
- Sudbury, Ontario
- 2019 srx
Hurricane PM bundle
2012 apex xtx
2012 vector gt
Tuners came on the 14 models here where i live.
