differences over model years between rage and vector
vectors are a mono shock skid. the rage is a proaction skid. you want an attack/apex ltx or a venture ltx skid and i am not sure the mounting on the tunnel is the same.
Whats the best way to convert a vector to a 136
‘06 and ‘07 Rage has the Mono, no-action suspension in them prior years. Mounting locations between the Mono and Proactive suspension were different, did a swap into my ‘06 RS Nytro years ago. What year is the Vec in question?
easiest would be rail extensions and tunnel extension from somewhere like tracks usa as a kit with the longer track.
Its an 07 vector the rear suspension on partzilla for a rage and vector look identical
Rails, rear arm, transfer rod, upper carrier wheels, coil spring, all different but similar.
Both are Monoshock skids.
Sled also needs a tunnel extension.
I agree with Maim, either order up a Tracks USA extension package or better yet, get in touch with @hibshman25 at Barn of Parts and have Travis put together what you need to stretch your sled to a 136. He’s a site sponsor and great to work with.
