vectors are a mono shock skid. the rage is a proaction skid. you want an attack/apex ltx or a venture ltx skid and i am not sure the mounting on the tunnel is the same.
mattison
- Mar 12, 2019
- RI
- 2010 RS Vector, 2011 Apex SE, 2016 Apex LE
2011 Nitro for 4 grand
2011 Yamaha FX Nytro - atvs, utvs, snowmobiles - by owner - vehicle automotive sale - craigslist
Very well maintained Yamaha snowmobile FX Nytro, 40th Anniversary colors. This sled is a gem. Always start in 5 sec. New: CVTech clutch PB80, belt, battery, carbides, hyfax, wheel ski, cover, extra...
providence.craigslist.org
yamahavector07
- Mar 14, 2023
- Minnesota
- 2007 yamaha vector
Whats the best way to convert a vector to a 136vectors are a mono shock skid. the rage is a proaction skid. you want an attack/apex ltx or a venture ltx skid and i am not sure the mounting on the tunnel is the same.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
‘06 and ‘07 Rage has the Mono, no-action suspension in them prior years. Mounting locations between the Mono and Proactive suspension were different, did a swap into my ‘06 RS Nytro years ago. What year is the Vec in question?
easiest would be rail extensions and tunnel extension from somewhere like tracks usa as a kit with the longer track.
yamahavector07
- Mar 14, 2023
- Minnesota
Its an 07 vector the rear suspension on partzilla for a rage and vector look identical‘06 and ‘07 Rage has the Mono, no-action suspension in them prior years. Mounting locations between the Mono and Proactive suspension were different, did a swap into my ‘06 RS Nytro years ago. What year is the Vec in question?
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
Rails, rear arm, transfer rod, upper carrier wheels, coil spring, all different but similar.
Both are Monoshock skids.
Sled also needs a tunnel extension.
I agree with Maim, either order up a Tracks USA extension package or better yet, get in touch with @hibshman25 at Barn of Parts and have Travis put together what you need to stretch your sled to a 136. He’s a site sponsor and great to work with.
