Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Whew, spent about an hour trying to mount my new Pioneer 13mm swaybar on my 2011 Apex. I used a ratchet strap to get the bolt holes lined up with the swaybar link. I hope I did this right, lined up the links equally with the hash marks, but the suspension feels VERY stiff in the front now.
I hate to take it out on the trails, only to find out that I need to swap it out for the stocker right away on the trails.
Did anyone else have such a difficult time mounting the 13mm swaybar?
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Something dosen't seem right there. Take your swaybar out and put the links on it on the bench and remark it. The marks might not be in the right spots.
Yamahammer485
The 13mm bar is difficult to install, but just in terms of putting the clamps on a floating bar. Maybe the links are out of adjustment due to worn ball joints?, they get no oil and can bind.
Also, prepare for mega wearing of your swaybar bushings, have to be replaced nearly every 3000kms...
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Don't worry about having the hash marks in the same spot on both sides. Just put 1 end on and then put the other end on aligned to the closest teeth. That way the bar is not preloaded one way or the other. As for bushing wear, I have approx 10,000km on by 13mm bar and just changed the bushings last year. And yes the front end will be stiffer.
No strap required so something is not right.
RxThunder
It was a breeze on my 03 Rx1, had the front of the sled off the ground, slid it in and it lined up with my marks on both sides no problem. I didn't worry about my marks being perfect, just so they slid on without preloading the bar.
blue er
yup marks propably not right on the bar, slide link off on one side as suggested.
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
Sled in the air ????????
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Reinstalled the swaybar, looks like it was 2 teeth off in spite of the marks on the swaybar. With the swaybar off and on a level surface, there was no way that both link arms were able to line up exactly with the other, so I lined them up as close as possible.
I will keep an eye on the bushings for wear...and I lubed them.
Hopefully, I'll hit the trails to test it out by the end of the week, thanks for the tips guys.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
You will also find your front spring adjustment to be much more sensitive--you feel the difference in 1 turn of the springs.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I pretty much have my front springs on full soft...that should be a good start no?
AIRWOLF
Guest
- Oct 1, 2004
- New York
- www.sledpartsgarage.com
bottlerocket said:No strap required so something is not right.
X2 they are very easy to install
snowbiscuit
13 mm bar is machined wrong
I've installed two previously on my Apex's with no problem. Just helped a friend with his and the notches were off and links would not align laying flat on bench, no matter what way we placed them. We maid it work but it wasn't right. If you got it from PP, I would call Bruce and let him know
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
We'll see how it works first.
whits-end
- Mar 2, 2004
Stock bar on a 2011 is 12mm, not 11mm like the older ones. You won't feel as much difference as older sleds but they work well. My 2011 Standard has 13mm bar and front springs set as light s possible. With the newer spindles I like it better than my '06 GT.
