andrew1984
is it possible to preload the swaybar in *one* direction only?
When I stand on the sled and shift weight side to side, only the left front acts stiff and the right side gives in a bunch before resistance..
Or maybe the right shock is dead?
I'd say a shock issue. If you want to confirm 100 percent, swap right and left shocks and try again, but I bet if you remove, you will feel the difference.
sk-rx1
Certainly possible to preload a sway bar, either by mistake or on purpose. Could have been assembled off one of two splines, that could cause it to act that way.
andrew1984
its easy to underestimate the value and strength of a front roll bar, especially a 13mm one.
i disconnected the front bar and immediately it told a story.
time for a rebuild!
time for a rebuild!
- 16K
