5valve
- Feb 3, 2013
- N. IL.
- Nytro, IQR, Redline’s, trailing-arm Polaris’s
I think this could be my daily driver. Take that tall paddle track off and stick a 1.5 inch on her. A little re-gearing and re-
clutching. I really like the ergos and the smoothness better than the 2012 procross turbo my buddy let me ride 3 weeks ago.
jimmyhighway
- Feb 6, 2006
- Northwestern Ontario
- 13 Skidoo Freeride 137
11 Yamaha Nypex MCX
I agree 100%. The Nytro ergos hard to beat. Rode back to back the other night, with a Sidewinder BTX, Which is a great sled. But something about those Nytros (with improved suspension).I think this could be my daily driver. Take that tall paddle track off and stick a 1.5 inch on her. A little re-gearing and re-
clutching. I really like the ergos and the smoothness better than the 2012 procross turbo my buddy let me ride 3 weeks ago.![]()
5valve
- Feb 3, 2013
- N. IL.
This sled is a little on the loud side. Gonna pursue an under-tunnel set-up. Lots of research to do!
5valve
- Feb 3, 2013
- N. IL.
Snowman871
- Feb 9, 2010
- Woodville, WI
- 2024 Polaris Assault 850
What's the backstory on the sled?
5valve
- Feb 3, 2013
- N. IL.
It’s a 2013 Factory Yamaha Hillclimb Racer. #789 Improver Class sled. Runs really strong. Has the trick front suspension. Both rear suspension air shocks have double reservoirs with clickers. Port Washington Yamaha got it from a factory auction. Has Power Commander fuel & ignition modules as well as an O2 sensor & module to monitor the fuel mixture.
Snowman871
- Feb 9, 2010
- Woodville, WI
Sounds like fun! Was surprised to see an MTX chassis with that front end.
5valve
- Feb 3, 2013
- N. IL.
That front end changes everything. I never liked the original front clip that yamaha put on the consumer Nytro. This race front suspension totally changes the sled’s personality.
Snowman871
- Feb 9, 2010
- Woodville, WI
The front end changes really helped my Nytro - I've still got the stock subframe (gusseted), but I upgraded to set of Mountaintech's 41" crossover a-arm setups and removed my swaybar. I made a couple suspension adjustments during the off season and my sled handles so much better this year!
5valve
- Feb 3, 2013
- N. IL.
Got the 1.5 on. The Maverick is in the foreground
5valve
- Feb 3, 2013
- N. IL.
5valve
- Feb 3, 2013
- N. IL.
Got the ice scratchers & RotoPak in place...
5valve
- Feb 3, 2013
- N. IL.
Today, I’m gonna pick up the new chain & sprocket gearset. Gotta bring down the cruising rpms....
jimmyhighway
- Feb 6, 2006
11 Yamaha Nypex MCX
I agree on the front clip, amazing difference in steering and handling. I finished installing one this year. You can push it hard at high speed through corners on uneven terrain moguls etc, it stays true and flat.That front end changes everything. I never liked the original front clip that yamaha put on the consumer Nytro. This race front suspension totally changes the sled’s personality.
