snowfever27
- Jan 7, 2015
- Vermont
- 2015 Arctic Cat XF7000
2009 Yamaha Nytro XTX (sold)
2007 Yamaha Phazer FX (sold)
2005 Ski-Doo MZX 800 Adrenaline (sold)
2003 Arctic Cat F7 EFI (sold)
2007 Yamaha Attack
2009 Polaris 600 Dragon SP
- Vermont
Last season I rode with un-insulated hiking boots because my XF7000 dumps so much heat out the foot wells. Heat robs power.... so I started looking at ways to get rid of the engine/exhaust heat. First thing I did, which was free, was make the upper vent hole in the exhaust side panel bigger. Hopefully now I will pick up almost 50% more air flow through the larger vent hole. The black panel shown is stock, white is modified. I used a hack saw blade and then cleaned the edges up with a utility knife with a brand new blade. I was a little aggressive, the vent is almost larger than I’d like, but it sure will breath better now.
After looking at some of the aftermarket vents I decided to pick up some 1/8” abs textured plastic at the hardware store and make my own. This plastic is rugged and I’ve used it before. I made a template out of poster board, traced it onto the plastic with a fine point silver sharpie marker and cut it out with a jigsaw. I cut very slowly, and very carefully. I’d be lying if I said I got it right the first try. I bought some ‘pet rated’ window screen and then stretched it over the abs cut outs and superglued the screen to the plastic. Then I drilled holes with a 1/2 Schrader bit and riveted the vents on.
The vents cost me a total of 10.49. 6.49 for the plastic, 4.00 for the screen material. But they took about 2 hours to make. Below is the drilling template I made out of the left over plastic.
Also, I removed some of the foam around all the stock vents. The vents on the bottom plastics are all but blocked by that foam, so I cut a few inches out so that air can actually move through the vents now.
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
Looks like some very nice work! Let's see the fully assembled product. I'm kind of following, but not 100%.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
What hardware store did you get the abs plastic from?
Never seen that product before.
Nice job
MS
Nice job
MS
snowfever27
- Jan 7, 2015
- Vermont
2007 Yamaha Attack
- Vermont
I’ll post some better pictures this weekend for you, I’m away on a work trip until Sunday.
snowfever27
- Jan 7, 2015
- Vermont
2007 Yamaha Attack
- Vermont
Aubuchon Hardware, I’ve only seen them in VT, MA, and NH. But you can get it online too, partsexpress has it. Go to their website and search for 1/8” textured abs plastic. Buy a few sheets, make some vents for your buddies too. Here:What hardware store did you get the abs plastic from?
Nice job
MS
https://www.parts-express.com/Search.aspx?keyword=1/8” abs plastic&sitesearch=true
snowfever27
- Jan 7, 2015
- Vermont
2007 Yamaha Attack
- Vermont
My wife took some pictures for me. This is the finished product.
This is the stock sized opening in the side panel.
This is the modified side panel opening that I trimmed to make it larger.
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
- YOUTUBE
- FrozenTows1
That most certainly should let the heat out! Bonus material....warm air blowing on your legs & torso.
Yes its very nice on the legs!That most certainly should let the heat out! Bonus material....warm air blowing on your legs & torso.
Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
Looks good, nicely done.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Question - did you use an olfa cutter to cut the plastic.
Did you do anything to round the edges
What did you find was the best glue to hold the screen on
Ms
Ms
JStat17
- Dec 30, 2013
nice work..........
snowfever27
- Jan 7, 2015
- Vermont
2007 Yamaha Attack
- Vermont
Ms
I used an Olga knife to take the edges down a little after I had cut the shape out. But you need something more heavy duty to do the majority of the cutting. I traced the shape I wanted. Drilled 3/8 holes in strategic spots so I could use a jigsaw to cut the shape out.
It was a little tricky. I cleaned up a few jagged spots with a flat file. I’m going to make some more vents for the side panels and I take some better step by step pictures.
snowfever27
- Jan 7, 2015
- Vermont
2007 Yamaha Attack
- Vermont
I scuffed up the gloss side of the plastic with 220 grit sand paper, then placed the screen on the scuffed side, then ran a super glue soaked brush over them. Carefully.I used an Olga knife to take the edges down a little after I had cut the shape out. But you need something more heavy duty to do the majority of the cutting. I traced the shape I wanted. Drilled 3/8 holes in strategic spots so I could use a jigsaw to cut the shape out.
