RX1 Yooper
I know someone with an 03 that has a stage 2 turbo, and runs even with a stock 03. He was told that it is normal because he is 50# heeavier than the other driver, and has an M10. Could those 2 things make that much difference?
impalapower
Yes I have heard from those who have had M-10's that top speed is lost. I cannot remember why, but didn't really care because I didn't want to lose any top speed. Yes I'd like to have a better suspension, but I'm not going to spend money to sacrafice my performance. Thats why they sell turbos, so now you're even spending more money. It doesn't sound right though, but a rider that weighs only 50 lbs more with an M-10 needs a turbo to keep up to a stock sled? A friend who also rides an RX-1 and who is about 50 to 60 lbs heavier than me with 144 studs will out accelerate me on my bone stock sled. That alone tells me that the M-10 is a big drag on performance.
Fergie
I hope the new mono-shock does'nt have that effect. :?
I installed my suspension at the same time as the turbo, so this is tough to answer. But mine is much faster even with the M10 than a stocker.
I will have a direct comparison soon, as I am in the process of installing the pro-action back in with SRX shocks to do some speed runs. I am building custom drop brackets so it is an easy swap between skids. 8)
You may want to look at the Expert X. Excellent weight transfer, Great ride and NO TOP END LOSS. Great suspension for alot less $...BBY
They do have weight transfer, but the ride quality is not as good as an M10.
I believe this will be a good solution, as it will be a 20min. skid swap. Also it should be faster than an RX1 shocked pro-action.
No doubt the M10 is the king of aftermarket suspensions with regards to ride quality. However it does have 2 things that I think are a big negative. Transfer and Top End loss...BBY
RX1 Yooper
Thanks for the feed-back. It isn't just top end. It doesn't accelerate better than a stocker either.
The only time the lack of transfer comes into play, is drag racing from a complete stoip. Normal riding which is what most people do, the lack of agressive transfer is an asset. This skid handles so well you can't believe it is the same sled.
You can excellerate into & thru a corner, beacuase of the lack of lift & transfer. This is much more fun to do than sit on the lake and drag race. IMHO
LazyBastard
Of course, it *is* nice to have them both... which is what you get on proaction, proaction mono, AND proactive.
Keith, Ever ride an RX1 with an Expert X in it?...BBY
sledheadgeorge
I've read somewere that you can get the transfer stops from a Blade and that will increase your transfer on a M10. But normally on a stock aplication the M10 is 5 to 10 mph slower on the top end and lacks the transfer you need for take off. But RX1 Yopper, your buddy with the 2 stage turbo has something that is not set up right. Even with the M10, and extra weight, that sled should rock. His clutching is off or he is not hooking upat all.
I have Blade blocks in allready, they do help.
Swiss Sledder
RX1 Yooper, here are links to a couple of threads on this topic, including some posts by people in your thread.
http://www.rx1.info/viewtopic.php?t=976
http://www.rx1.info/viewtopic.php?t=3567 (read post by Dukster)
http://www.rx1.info/viewtopic.php?t=2993
There is no question the M10 kills your performace. We did a side by side comparison with the m10 and the X. the sleds were identical clutched,geared, and stud quanity. in 660 the X was 5 to 6 mph faster and 8 sleds quicker. in 1000 feet it was 8 mph and 12 to 15 sleds quicker. We used a GPS for MPH.
the M10 is the plushest ride. The X is 20 times better then stock. with the M10 being 30 times better then stock. I've orde both extensivly!!!!
