Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Did a search and could not find the answer.
Does the 07 Apex GT have the 4.9, 5.5 or 6.1 spring?
Is the valving of the Ohlins better in the 07's than the 06's?
TIA
Rice
TIA
Rice
SERPAGS
Same valving, and it is the 4.9 that comes stock.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
Well that sucks!!!!!
Thought they would change the valving at least.
You would have thought they would have made some changes other than adding the extra support brackets.
Thinking of getting an 07 on the cheap.
I rode my wifes Apex GT last weekend. Made my Warrior seem like a dump truck by comparison when I got back on it.
Thanks for the reply SERPAGS.
Rice
Rice
Valving on the 07 Apex GT is different than the 06. The compression stack has been changed. You do not need to revalve an 07 unless you change the spring.
SERPAGS
ddd
Thats good to know because I have been VERY mixed responses on this subject.
watersuper said:Valving on the 07 Apex GT is different than the 06. The compression stack has been changed. You do not need to revalve an 07 unless you change the spring.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
Anyone know what '08 Apex 40th Anniv. has for valving and spring vs. '06GT, is it stiffer valving only with same 4.9 spring??
SIMMER
BADSLED said:Anyone know what '08 Apex 40th Anniv. has for valving and spring vs. '06GT, is it stiffer valving only with same 4.9 spring??
I don't know about valving but I just switched to a 6.5 spring and the stock one that was in mine was a 6.0.
apltx08
Here's Pioneer Performance chart, go to SHOCKS & SPRINGS and scroll to the bottom and he's got all the springs and model year listed...
http://pioneerperformance.net/
Honk
I went from the stock 4.9 to the next size up. 5.5 and a revavle worked well for me. 07 GT 200lbs with no bottoming out
