Hey guys looking for a little help on how much weight to put in my weights. Right now I have a bolt in each hole. White primary spring, 16mm rollers.Rpms seem pretty good but looking for a little better setup for short drag racing. Usually 500 in snow. I have a 07 attak all stock for now. Also what helix and secondary spring is a good combo?
Thanks John
Thanks John
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Black HC spring. Bolt and 2 washers in center and OD ( 3.2 grams ) 3/8 inch set screw in tip (1.4 grams ) and bolt and 2 washers in heel ( 3.2 grams??--I don't have my scales right now ) Weight should be 75 grams total. Stock secondary.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
p.m. me or call and I'll set you up
Thanks guys
