satan660
ok just traded in my 08 apex ltx for a apex mtx...my apex was fast 119mph on gps...not so good in the snow..... :exc:
looking for some feed back guys...
the track on this is 16" wide....2"1/4...162"
now wantting to cut the lugs down to about 1"1/4....run 1"1/2 studs
and some gearing....
right now still breaking it in.. bone stock 155 on speedo on snow (lake)
just did some clutching now 165 on speedo
looking for a set up for a 1500' foot runs
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Satan660,
You should have added six more to your user name! LOL
165 on the "dream meter" with a MTX????
Welcome to TY! Please add your location to your profile.
satan660
why is that hard to belive.....with a mtxBlue Dave said:Satan660,
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
U have that speedo set in metric because that would be just over 100mph which is more realistic.
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
TBay Sledhead said:U have that speedo set in metric because that would be just over 100mph which is more realistic.
Yep.....
satan660
yes pulled 93.3mph on gps......on groomed trail.....and 106mph on speedo
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Sure, now cut the track down. Make sure the get tunnel protection in there if your going to stud. You won't be able to run 1.5 studs however. 1.32" Woody megabites scratch the tunnel as it is with 1 1/4" lug track. I don't think the MTX comes with protectors.
satan660
yes there are no protectors on it.... will have to put some...i ran 1.375
on my attak seamed ok. hope i can run the same on this one
tundra
If you have stock gear 20-40 dont expect to see much more than that. (its already over theorical top speed)
And if you have stock clutching, maverick, i guess its long seeing that speed.
I ran 92 mph GPS with a 2.5 inch track under 1000 feet, still climbing, but i should say, that was pretty much over. And the Helix isnt going further (machined) Clutch are fully closed.
Apex isnt stock too (lighter,different exhaust, and suspension)
I guess, with a 162 with low height lug, different gearing, 100-105 is pretty much the top.
But, with a challenger, good clutch setup its an awesome drag sled.
- 8K
