musselmark
Is it possible to buy a drive axle bearing that has the old style rubber seals, I like being able to re-pack them with grease. The new ones are sealed with non-removable metal shield/seals.
All of them that I get from Yamaha have removable seals..
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
Correct and royal distributing (as well as any bearing supplier) sells the ntn bearing with the removable seals
yamahahaapex
our 5 star dealer went to the steel shield covers and I voiced my opinion on those. I was told you don't need to service them every year and they are completely sealed with this new feature. I grabbed one to test it out last year and at the end of the season I will have my findings. Either way Im opting for rubber seals next change over
Don't forget the deflector, early sleds did not have it. 8FN-47377-00-00
http://www.ty4stroke.com/threads/dr...cap-longer-lasting-bearing.56389/#post-491181
musselmark
I ended up prying the steel shield seal out and re-greased it. The original grease looked good, it was pink in color and nice and clean. I repacked it anyway, it is harder getting the seal out but it will come out.
HABS 1
- Oct 22, 2015
- corunna,ontario
- 2006 apex gt,136 Hartman ext,dalton clutched,full excel exhaust,yamiheaters,cna pro ex white skis,hid lights,mtx riser,1.5 intense track,etc,etc!---2021 sidewinder xtx se
how many miles on it ? with it still lookin good? i tried to get metal cover off once and damaged it getting out so i just replace em but would be curious as to the milage on it and still good and cleanI ended up prying the steel shield seal out and re-greased it. The original grease looked good, it was pink in color and nice and clean. I repacked it anyway, it is harder getting the seal out but it will come out.
musselmark
I would guess approx 1500 miles . Another idea might be to drill 2 tiny holes in the seal at 12 and 6 oclock just big enough so that a needle grease adapter would fit in. Pump grease in one hole and let the access/old grease come out the other then clean with brake cleaner and silicone the holes. I did damage the seal slightly but fixed it and it went back in nicely.
HABS 1
- Oct 22, 2015
- corunna,ontario
ya herd the whole drill hole thing, dont like the idea i would just replace!I would guess approx 1500 miles . Another idea might be to drill 2 tiny holes in the seal at 12 and 6 oclock just big enough so that a needle grease adapter would fit in. Pump grease in one hole and let the access/old grease come out the other then clean with brake cleaner and silicone the holes. I did damage the seal slightly but fixed it and it went back in nicely.
