sethryder
- Feb 19, 2014
- Derry NH
- 07 phazer fx
hey,
It seems that at higher speeds, 55mph and higher, my drive belt is contacting the bottom of the belt guard intermittenly. I can hear it, and see streaks on bottom of guard and a worn spot on outside top edge of belt. Anyone know what would cause this?
Thanks!
Thanks!
71rdrnr
- Oct 12, 2009
- Winnipeg MB. Canada
- 2010 phazer RTX
Bent guard? It's a close fit normally anyhow.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
The secondary not back shifting quickly enough might allow some slack in the belt, or the wrong length belt. Just a couple of thoughts.
ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
Wrong belt, Belt starting to break apart, Possibly blown bearing behind the secondary?? Pulling secondary forward and up under load??
Pull belt, pull secondary off (one bolt, super easy, make sure to place shims back in or loose any) Wiggle shaft. You'll be able to inspect bearing.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
These guys are on the right track I think.
sethryder
- Feb 19, 2014
- Derry NH
- 07 phazer fx
Thanks everyone. The belt is a yamaha 8gs. Old phazer belt i believe. It is in good shape. The belt guard did not appear to be bent or mishapened either. I will check the bearing and dive into the clutches when i get a chance. Thanks again
