kingtut
- Nov 1, 2013
- Traverse City, MI
- 2006 Apex
How do you remove thee things? What i have done so far is take off the chain case and the bottom gear and the speedo bearing cover. I can slide it out the secondary clutch side, but the bearing gets in the way to pull it out towards the chain case side. Is there a special way I need to take off that bearing? This is almost the last step for me to put on a new track, just have to take off the tunnel protectors.
marq
- Apr 14, 2003
- Bridgman, MI
- 2006 Apex RTX
Did you remove the two set screws from the bearing race on the speedo side?
kingtut
- Nov 1, 2013
- Traverse City, MI
- 2006 Apex
marq said:Did you remove the two set screws from the bearing race on the speedo side?
Where are these located and what do they look like?
marq
- Apr 14, 2003
- Bridgman, MI
- 2006 Apex RTX
They are on the belt side bearing housing inside the tunnel. There are 2 set screws that you'll need to remove
They are listed as part #7 in the parts diagram for a 07 Apex RTX, listed under TRACK DRIVE 1
marq
- Apr 14, 2003
- Bridgman, MI
- 2006 Apex RTX
The screws aren't very long.. a 1/4 - 1/3 inch maybe?
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
they hold the bearing to the shaft, usally are a torx drive and on the inside of tunnel. loosen them and pry the bearing off with a big screwer.
kingtut
- Nov 1, 2013
- Traverse City, MI
- 2006 Apex
Yeah I hate these little screws, I lost the one for the oil seal for the chain case somewhere in my garage...so pissed.
