turbotime99
- Jan 20, 2014
Hi my first post on anything ever lol. Ok I have an apex 07 mcx blew the drive shaft bearing and speed sensor. then drove 40 km in limp mode check engine light on and yellow warning. Then my sled overheated and spit out some antifreeze now red light is on. Is red light low coolant? Also bearing is destroyed and driving it so far it was grinding the bearing cover on the outside and the riveted cover plate on the inside. So how much trouble am I in guys.
Put a new bearing in and see how it sits if need be change the bearing cover. Of course your going to need a new speed sensor and gear to. Take a good look at your bearings on the chain case as well.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
There is a coolent hose right there check the hose of a hole. If it over heated bad the motor is going to be in bad shape.
turbotime99
- Jan 20, 2014
How about the red warning light does low coolant set it off. also if I bypass the tors will that effect my rev limited
turbotime99
- Jan 20, 2014
It over heated I seen the warning and shut it down didn't stall or seize
APEX 06
- Apr 30, 2009
- Sheboygan, WI
turbotime99 said:How about the red warning light does low coolant set it off. also if I bypass the tors will that effect my rev limited
The Red light was mostly for it overheating/bearing-speedo, the sled wont know its low on coolant.
turbotime99
- Jan 20, 2014
Does anyone know the reasons the red light could come on?
turbotime99
- Jan 20, 2014
Ok yellow light and engine light is for speed. even when cold now the red light is on with yellow and check engine light. When I first blew the speed and bearing it was only yellow and engine flashing the code for speed and tors. The it overheat let her cool down and the next day cold start still red light and yellow and engine check and same codes
Unplug the speedo sensor it could be causing a false light to show up.
turbotime99
- Jan 20, 2014
The speedo is blown apart and it gives a yellow light. I was wondering for what reasons a red light would come on
turbotime99
- Jan 20, 2014
Is there a link or somewhere I can find a list of red light faults. Can't find it in service manual. Might need a diagnostic computer?
is your coolant low? Is your oil low?
turbotime99
- Jan 20, 2014
No its going to the shop I just called them thanks for the info guys. love the sight lots of good stuff here
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Did you let it warm up the next day to see if red light went off?
Red light comes on when cold and goes out when it is warm enough to drive.
turbotime99
- Jan 20, 2014
Isn't that a yellow cold light its an 07 apex
