turbine man
sliders
i have gone thru 7 pair on the same sled in one year, getting good at changing them.
steve barber
my dealer just got a set in. he sold them to me and putting them in today. they have little holes in them, mybe to hold snow when there isnt any. I GOT 900 MILES ON THE FIRST SET 2011SE. I THINK I WILL PUT A MARK ON THEM SOME HOW, A GRIND LINE ABOUT 1 INCH LONG IN THREE SPOTS SHOULD DO IT
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
the little holes are from the mounting of the vespel to the slide.
CaptCaper
- Jan 1, 2007
- Northern N.H.
steve barber said:my dealer just got a set in. he sold them to me and putting them in today. they have little holes in them, mybe to hold snow when there isnt any. I GOT 900 MILES ON THE FIRST SET 2011SE. I THINK I WILL PUT A MARK ON THEM SOME HOW, A GRIND LINE ABOUT 1 INCH LONG IN THREE SPOTS SHOULD DO IT
Figure out the mm or sae measurement and use a open end wrench to check the wearing with. When the wrench fits on the slide it's time to change.
sherlock29
Can someone take a pic of the end of the slide to see profile?? and of the bottom?
turbine tester
- Apr 8, 2011
- PEI Canada
- 2006 Attak
So I have a 1.25 ice ripper track clipped on every 4th Bar can I use these new slides???
darv
- Aug 9, 2005
- 08 Apex 40th LTX
yes these would fit any sled from about 1993- present & yes to the above post
I always harden my sliders first before install with map gas,[get them hot].heat-cool-heat-cool-heat-cool on snow or a spray bottle with some ice cold water.i do this cycle 10 times,they last a very long time in general use and all sorts of conditions we all run over at times>dirt,snirt,ice,pavement..and when i get there they can take the heat.not going to spend $$ on these slides,im sure they work but there a wear item...
