Dyno sheet "FOR MXZ900" or on amsnow MXRX1
jtssrx
New Baltimore,Michigan
Here ya go. This pulls was at 15 pounds. The intake temps were 100 degrees. It was one of are first pulls before we made jetting, Waste Gate and Air filter changes. the highest intake temps we had were in the 140 range and that was after countless pulls. We tested the sled at a local grass drag event the day after. We couldn't get intake temps over 90 degress. It was 61 degrees outside.
when the picture comes up it is small. simply click on the picture and a button will appear at the bottom of the screen with 4 arrows. click that buttom and it will enlarge the photo.
The highlighed area is were the dyno loads the motor properly. The other numbers are what the dyno is picking up but inaccurite except for the RPM. I used the highlighter to help everyone see the numbers better.
I don't know who mxrx1 is jtsrx, but the Dyno pulls look good.
I would like to see the later pulls after tuning as the numbers you posted at 15lb. are very close to Benders at 8lb. Intake temps look good also.
MXZ900
If it's not you I apologize. Thanks for the kind words. I think everyone offers nice packages.
we are going back to the dyno in a couple weeks. I will post dyno pulls on pump premium from 5 to 8 pounds and pulls on 105 from 9 to 15 pounds after we make some changes.
The sleds flat out flys. we ran with pro stocker 800's in 500 and consistently beat them. We were not setup for 500 feet with gearing or suspention
