Miller’swinder
- Dec 27, 2017
- 17’ Yamaha sidewinder
I’m a big guy and need to stiffen my suspension on my 137 ltx-dx. Shitty shocks and springs on it. Anyone have any ideas that won’t break the bank ?
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
4 sided torsion spring adjusters might do the trick. Yamaha sells them and I believe BOP has some too. $60-$75
I put a 160lb spring on my front track shock suggested by Cannondale and it works wonders as well. $50
Sent from my iPad using Tapatalk
Miller’swinder
- Dec 27, 2017
Ok. Yeah I’ve seen the 4 sided adjuster. I got bigger front spring blocks already but will try those as well. As long as the springs can handle it. And where did you get the 160lb spring?
PigeonLake
I did the stiffer spring and Elka shocks. At least the stiffer spring is the minimum investment I think
Miller’swinder
- Dec 27, 2017
How much was the Elka Suspension. Just the back shocks or all the way around?
lilrez
- Feb 7, 2016
- Near Ottawa
160lb spring number handy?
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
I ordered a Cat one.
Part #2704-229
Part #2704-229
PigeonLake
Springs, stage 3 up front And stage 4 in middle and back. Around 4 k including tax and installation
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Yikes...They sure don't give that stuff away. Do you have to be Johnny snowcrosser to appreciate the set-up, or does it provide a lazy boy recliner experience down the trail? I've got the RR/LE shocks and think those are awesome, can't imagine how much better you can get. JmhoSprings, stage 3 up front And stage 4 in middle and back. Around 4 k including tax and installation
- 12K
