micaelaman
- Dec 3, 2014
- Sweden
- Sidewinder MTX 162, Arctic Cat M800 HCR
Hi,
I bought a used Sidewinder this weekend. The seller said that the instrument cluster had been replaced so the milage are to low. He also said that the hours is stored in the ECU so the hours are right.
Does anyone know how and where this things are stored?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Lower right button on cluster. Cycle thru it will show hours on dash.
micaelaman
- Dec 3, 2014
- Sweden
I might been a little vague. My question was if the running hours is stored in the ecu so that the running hours will ramain after a instrument cluster replacement.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Hours are stored in the ECU , mileage in the cluster.
Replace the cluster your mileage is gone but the hours are maintained in the ecu and the cluster will read the hours off the ecu.
micaelaman
- Dec 3, 2014
- Sweden
Thanks!
I wilk do some further investigation.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Is the sled flashed with a tune? If so (its possible)while its started motor running that hour meter display becomes your boost level. Check it with the key turned on and engine not running if it has a single tune on it.,.
- 7K
- 10K
