Does anyone know what part the ECU plays in the IQS shock setups and Power steering? I saw the PNs are the same for all the different models but was curious if one could use an ECU from a none equipped PS and IQS sled on a sled with both of those options?
Most likely. The iqs module has its own controller. The ecu on the sled is just translating the button push into what is sent to that controller. On sxs / UtVs you can add iqs afterwards and the kit comes with a 3 position switch. If you look on the fox site for iqs you will see what I mean.
