Fanderson
- Oct 25, 2010
- Western Montana
- 2007 Phazer Mountain Lite
I have a 2007 Mtn Lite and am in need of a new ECU. I see there is a part number difference in the "mountain" phazer models vs others. Can anyone tell me if an 8GC-10 ECU (non-mountain) will work for my sled? I can't find a reasonably priced 8GP-10 (mountain) ECU anywhere. Thanks!
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Personally, I can't see why it wouldn't work or what the difference is. Maybe a different power band because of the longer track or gearing? Even my MP uses the same ECU as the Phazers. The only difference is with -00 and -10 where the -10 is the updated one for cold starting.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Just the speedo calibration is different, putting a short track ecu on a MTX/XTX will throw the speedo even further off. Instead of reading 7-8% fast it will be reading 18-20% fast.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
That might be it. Does the MTX use a different cog? Track length has no bearing on speedo.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
8 tooth on the MTX/XTX, 9T on the shorties
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Then that's likely the difference on the dream-o-meter. I'd take an ECU from a shorty for the sake of getting the sled running and price. I'd use a GPS for any kind of accuracy.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
I should toss in an ECU out of a short track, bet I could hit 100mph! have seen 92 on the speedo of my MTX (84gps)Then that's likely the difference on the dream-o-meter. I'd take an ECU from a shorty for the sake of getting the sled running and price. I'd use a GPS for any kind of accuracy.
2stroken
So are all of the ECU compatible across all years of the phazers?
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
The only change that I can see is 2010 changed the way the low oil pressure system works, not sure if there is an extra/different sensor for the system.So are all of the ECU compatible across all years of the phazers?
2stroken
So are they interchangeable?The only change that I can see is 2010 changed the way the low oil pressure system works, not sure if there is an extra/different sensor for the system.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
It could just be a display thing on the pod, basically working along with the low oil pressure light, rather than a change in the ECU programming. My wild hunch says it might work.
I think it's a definite "don't know".
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
To be 100% sure the 07’ to 09’ should interchange and 10’+ should interchange.So are they interchangeable?
Joey_306
Any else tried this?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
More than likely it will work but your speedo will be off. I think that's why it has a different part number because the MTX has smaller drive sprockets.
They are all interchangeable to at least run the engine. Not sure if things like reverse or Speedo are effective. My 07 is original ecu and has been used as test ecu in almost every configuration they made. Always at least got them running.
