EFI controler fron ULMER
SharkAttak, at this time we're not releasing any numbers. Everything will be released when it all becomes available.
Charged RTX, I think you may need to reread the post. Just our fuel controller should be in the $340 area where as I believe Fix Powersports are saying their fuel controller is $500. The complete fuel controller and ignition controller (adjusting both the fuel system and ignition system) will be around $700.
On another note, taking off on Thursday for a few days of testing at some different elevations and seeing how the mapping matches up there as well on the Phazer and Apex.
Yes windage plates are in stock.
One more question. I was talking with Dyno Ray about cams and head porting. He said that with the Power Commander it will make another 10hp on top over just using the Boondocker setup which does not adjust timing. Something about the stock cdi pulls back timing on top which limits power. Can we expect some significant gains with a mostly stock motor? Say 4-5 hp on top.
