Electrical Help Needed
NytroGrizzly
Innisfil, Ontario
Hello,
I have a 2009 Nytro RTX and I melted my tail light when my aftermarket exhaust blew the end cap off. I drove the sled for a few km's then I ordered a new tail light assembly. I installed it and now it wont work. The 20 amp fuse for the lights is good and when I test the tail light connection thats by the reverse lever there is no power??? I am stumped because if the snow was going onto the melted tail light it should have blown at the fuse??? is there another fuse for the tail light somewhere?? what are some of your opinions on this as its driving my crazy ????
Fuse is # 56,#40 is rear taillight,#39 is breaklight switch. Make sure you have power on both sides of the fuse you replaced. If you don't and already replaced it you probably have a short downstream of fuse to light or brake switch. Also check your grounding. Attached electrical diagram to help.
Good luck
Pete
