slimjim2525
Asking for a friend. 2019 SRX. He tells me last night the sled started no problem. Put it on his truck and let it run for a few minutes, then it suddenly shuy off. Now, has no power to anything. It is not the kill switch he claims. Any ideas?
Check you batter connections and then check fuses in fuse block. Then pull fuse block and check under it for rub throughs wires.
slimjim2525
30 amp fuse blows every time it's about to start. Any help with this new info?
sideshowBob
If all the wiring, and the battery check ok then it sounds like the voltage regulator could be at fault...not an uncommon issue on these 998s.
Pay particular attention to the wiring harness under the fuse block where rub throughs have been known to happen.
Also look at the engine mount left front. You can see this by looking in clutch side just in front of primary and above. Seen some rub through the loom and into wire(s).
