Electrical problem and engine bog
Bake Relays - Didn't make any difference. There was corrosion on them so it was worth it to pull everything off and clean/protect them with grease. - same for starter relay.
Changed Plugs - needed to happen anyways, but I don think it made any difference specifically to this issue.
Throttle free play - thats the ticket. I adjusted it to 3.5mm at the throttle lever and it seems to run better.
Cant say for sure yet, because I need to get out on to trails/moutnains, but she seems to run like a sled again.
Question I have is: how does the throttle cable get shorter!?
Everything was tight in there, but over the last 3000km, the throttle cable must have shrunk since the gap was too small.
