BoonDock Saint
wondering if this is a simple fix for this problem? I have an 2009 xtx, started up couple weeks ago, noticed engine braking no longer engages, idling remains high around 2700 after warming up, riding around reducing speed, I have to use brakes to actually stop or slow down. Anyone here have or had this problem?
BoonDock Saint
No codes, runs, rides with no problems
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Have you tested the ISC in diagnostic mode?
Pete
Pete
herndonp
- Nov 28, 2012
- Freedom,NH
Here is info from troubleshooting section in manual.
herndonp
- Nov 28, 2012
- Freedom,NH
Have you checked for the wire rub issue on the clutch side? https://ty4stroke.com/threads/wiring-harness-rub.131747/
Pete
Pete
BoonDock Saint
Thank you Sir, I will update after inspection/ troubleshooting
herndonp
- Nov 28, 2012
- Freedom,NH
Good luck. Yes let us know what you find.
Pete
Pete
herndonp
- Nov 28, 2012
- Freedom,NH
Any update on your issue?
Pete
Pete
herndonp
- Nov 28, 2012
- Freedom,NH
Did you find a fix yet?
