YamahaFreak
The Pen is Blue
http://www.youtube.com/watch?v=5GwfeUnR6Ts
Engine just takes a beating and doesnt blow up.
Came across this on youtube this is unbelievable
SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
WOW
Delta_T
That movie is made in my neck of the woods.
Unbelievable!
I have seen some water skipping, but this.... I didn't know you could do that. I am not going to try.
Unbelievable!
stephenpen
It looked like he was going down a few times. It sounded like the belt was getting a little wet causing him to hit the rev limiter.
NFLD-Nytro
Exactly. I felt nervous just watching, I couldn't believe he didn't head for shore when his belt started slipping.stephenpen said:It looked like he was going down a few times. It sounded like the belt was getting a little wet causing him to hit the rev limiter.
I used to love running water, but won't do it with the Nytro. I hate the thought of sinking it.
stephenpen
Ya thats big balls not to head to the shore. A couple years back I took my zrt 800 out on Georgian bay in August. It was a blast and I felt safe doing it. The Nytro is totally different on water. Mine does not like water.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Epic
Snicks
I'm speechless. WOW!!! I've seen sleds sink after they hit the patchy ice...he just kept going like nothing. Cool Vid! Thanks
Newfie Apex
- Mar 3, 2010
- Mt. Pearl Newfoundland
- 2008 Nytro
ice
Cool ...would I do it with my Apex NO...would I like to YES!!
YamahaFreak
The Pen is Blue
I cross water alot with my Nytro but nothing like this!
I know its kind of simple to get a 2 stroke going after sinking, but what all needs to be doen if you sink a 4 stroke?
Straight_up_XTX
I would think you would have to drain the oil and pull the plugs and turn it over a whole bunch... Then run it for a bit and drain the oil again. At the very least anyway.
Possibly even disconnecting the header to get all the water out of the exhaust... I immagine any remaining water would be wanting to flow back into the engine.
This is also asuming none of the electronic fuel injection components are not fried from being submerged.
It's a scary thought! Lol!
YamahaFreak
The Pen is Blue
Lots of work i can see, well dont plan on sinking mine but good to know you can at least save it hahahaha
basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
Just think of all the hyfax he is saving
- Nov 1, 2009
- 2009 Phazer RTX
Probably have to change the oil a couple times before the water gets out. All the electrical connections would need to be greased. and much much more.
