engine light on
snowfreek20
Traverse City, MI
Hello gentlemen, Ok I have had my sled torn apart all winter finally got it back together and now i have an engine light blinking, the last time i ran it had no light! so all the stuff i did that is a possiblity, I extended all the wiring going up to the handlebars. Could the motor detect a wire come loose? I also was in the carbs, only the top half, I raised the needle to compensate for air filters, I haven't rejeted yet, I had the filters on the last time i ran it and had no light! then the only other thing that i did was changed out the brake line. So any suggestions? Also am having a problem with the sled falling on its face under throttle, I was thinking it was still running lean, but pulled choke out and ran worse, so I think I will put the needle back down and pull choke to see if i can get it to run better and I think that would tell me what i would need to do as far as jetting! am i wrong? any suggestions would be appreciated! By the way, i got the filters off of ebay so i didn't get any jets with them they are Gytr brand Thanks fellas!
If you were raising the handle bars and didn't use a longer throtle cable you may be activating the tors switch. Check your routing of your cable but if you went more than 2 " that could be your problem.
what code is it blinking, like 2 short 1 long or 8 short etc
thanks guys, according to the warning codes it looks as if i have a short circuit in my hand warmers! now i just have to find it! thanks a ton
ok looks like i found that the warning code stands for a short circuit in the hand warmers now i just have to find it! thanks for all your help, but one last question, what style of jet is used for the main jet, i'm going to have to order them on line, Thanks a ton guys
