Glenn
In my 2006 Venture the manual tell me to use a 0W30 engine oil it does not specifie mineral or synthetic. Is Yamaha Lube the 0W30 a mineral oil or synthetic oil?
hondo
Yama-lube is a blended "semi-synthetic" oil.
Yama-lube has been good to me for over 12,000 miles in two years.
The sled does not burn any oil between oil changes.
That's all I use.
That's all I use.
yammie3687
- Dec 14, 2005
Use the yamaha blend oil 0-30W. You cannot use synthetic oil the starter clutch will slip.
Tfin
yammie3687 said:Use the yamaha blend oil 0-30W. You cannot use synthetic oil the starter clutch will slip.
I've heard others say this as well, but I've heard from even more who say that there isn't an issue.
Anyone else care to comment on this?
twomorestrokes
Yes, I've read this in Yamaha's literature. Several others use full synthetic and say it's fine, but IMO when the engine manufacturer makes a point to say to stay away from something, I'll do it. I'm usually a big fan of full synthetic.
Canadian Lad
The dealer told me to use synthetic - said it was recommended by Yamaha
Sled Dog
I have full synthetic in my bike and my sleds no problems at all.
STORM-CHASER
with the money you have invested, Just use the yamalube.
Oak Hill
I use Mobile 1 0w30. 4000 miles and no issues.
Jack_Shaft
Also interested in hearing about this one...
I run Mobil 1 synthetic in my Tacoma & Protege and was hoping to put it in my RX-1 as well.
I wouldn't go against Yamaha's recommendation to stay away from fully synthetic oils, but that does seem odd.
BoostMe
My dealer also tells me to not run full synthetic because of the starter problems, his dealership has had some issues. IMO most change oil every season, this is gennerally not near enough hours or miles to brake down a standard oil. I do believe the synthetic would disperse heat better possibley for a turbo application?? Anyone? Scott
The deal here is not really if its syntetic or not... it is:
1- do not go above API SF
2- do not use anything that have anti-friction additives
3- do not use anything that says "Energy Conserving"
I have found some Castrol Syntech 0w30 full syntetic that met all 3 conditions last pre-season, used it all winter (2 fills) and had no problem whatsoever.
Using the recommended Yamalube is always a sure shot.
2 cent in...
2 cent in...
sledheadgeorge
For those of you here in Canada, Canadian Tire has the Formula 1 semi synthetic lube on sale this week for $2.99 per litre. I think it meet the same specs.
AVenture,
Where did you see those strict recommendations on not what to use.
As for point #1 I thought service grades were backward compatible.
I slightly understand your points #1 and #2 as maybe the anti-Friction and Energy conserving go together and that is what the starter slipping is about.
On the issue of Starter Slipping. I don't get it. How does oil effect the starter.
twomorestrokes
The starter has internal wet friction discs.
