Engine problems - blew oil line
inlet ny
yamaha rx1
hey guys I had an oil line blow out and no lights came on and I felt a vibration and then here a squeal and it shut right down. I towed it back to my garage filled it back up with oil and put the line back on. It started up and then I shut it down and restarted it and the squeal went away but there's a knock. Always I was just wondering what kind of problems i am going to face , crank pistons, or whatever I know I won't know till I get in there but I'm just wondering what everyone thinks before I start this project and if maybe a new motor is in the picture? :/
Rod bearings for sure probly..
Had an 03 with bad oil line, thought was low on fuel when light came on but when I got to fuel it up oil was running out the bottom. Fixed the problem an less than 500 miles later she just stopped running.. Rod bearing failure.
