temagami
- Nov 20, 2008
I have by passed my tors but nytro just about dies and light flashes with check engine light comes on for a scond then it resets itself before i can read code then runs fine sometimes is when i punch it and some times when i am just excellerating can i bring up past codes
fxnytro1050
check the harness behind the primary?
yamanytro121
sounds stupid but i had that isseu before and it was my positve battery cannection was a little loose.
temagami
- Nov 20, 2008
I tired to pull out my wiring harness found a pile of green corroded wires and plugs try to solder up but have to order new harness
