I need help with a little problem. My 2018 Sidewinder will get stuck at 70 MPH no matter how much throttle I give it. It's quick up to seventy, then I give it more gas, even to the bar and its just stuck there. It will on occasion "free up", and I can feel it, and then will accelerate. Gas is fresh, runs fine, no codes. I had the fuel pump tested last year when it was sputtering, and was fine at that time. Not sure what's up.
Miskow
- Jan 29, 2023
- Minnesota
- 2018 sidewinder, 2023 sx Venom, 2006 Apex
Throttle position sensor?
Have you checked how to see the digital reading on your instrument cluster. Watched a video on YouTube that tells you how to read what your throttle is reading as you depress it.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Are the clutch's sticking? The primary not fully shifting out? Weight getting stuck?
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Check your primary spring to make sure its not broke.
Good idea on the clutches, will check them out.
