dirk
I got one of three out easily, the other two were quite the struggle and one is now in two pieces. What can I use instead of oem hardware?
darv
- Aug 9, 2005
- 08 Apex 40th LTX
There is up-date parts for this it comes with gasket an new clamp with ss bolts
dirk
Well I've already got the copper donuts coming and read about taking some material off the spacers so they clamp tighter. Trying to not go to the dealer of possible.
yamaha convert
dirk said:Well I've already got the copper donuts coming and read about taking some material off the spacers so they clamp tighter. Trying to not go to the dealer of possible.
Taking material of the clamps spacer will only make it pull down tighter on that side and give you a clamp that is not pulling up evenly on both sides. It will pull the clamp down on that side and the clamp will be out of round.
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
And the SledToyz donuts (if that's what you ordered) are already slightly thicker than the Graphite which has a similar effect.
dirk
Yes I did order the sledtoyz donuts. So I don't need the updated clamps? and can I use a regular 8.8 grade bolt instead of the oem Allen heads?
yox185
The only issue with a non-Allen head bolt will be fitting on the clamp. Hex head is too wide. Other than that there is nothing special about the Yamaha bolt.
