00-NUKE
That's ALL been helpful. I'm looking for a slip-on. At least now I have some ideas. I BARELY got beat by a 2006 FST Classic last winter so the extra snort will help too.
shadow44
Well if it's a slipon you want then go with the Hindle, 3-4 hp across the entire rpm range and 10lbs weight loss...I would also recommend some type of fuel programmer ( PC3, PC5 or RB3 ) as it will lean out.
BooBoo
00-NUKE said:That's ALL been helpful. I'm looking for a slip-on. At least now I have some ideas. I BARELY got beat by a 2006 FST Classic last winter so the extra snort will help too.
You want it to run then put on some of Ulmer's goodies. I'm running Ulmer's header, K&N kit, stage 1 clutch kit, PClll, and I have to say it run's hard. With this set up the 06 FST classic will see nothing but tail light LMAO!!!!!!
ruffryder
didn't you remove the hindle from your sled?shaddow44 said:Well if it's a slipon you want then go with the Hindle, 3-4 hp across the entire rpm range and 10lbs weight loss...I would also recommend some type of fuel programmer ( PC3, PC5 or RB3 ) as it will lean out.![]()
shadow44
Just for one weekend, but that's when it went to Dynotech...it came back in stock form as they did the stock run last. It now has the stock header with the stealth slip on...plans were to test that setup but we ran out of snow and right into warm weather...but I still plan on testing that setup next season. I'm going to try to get a sound clip up when I get some time.
Groomer08
sneaky....
gotta watch out for the FST's.
if you have someone who knows their stuff, u can crank up the boost using factory computer programer.
my cuz works at poo dealer and his buddys sled was in so he hooked it up and fiddled and farted around and he got the boost up a few pounds.
funny cuz 2 guys bought sled same day, now they race and orange one wins. guy with black one is baffled. guy with orange one wont tell his secret.
too bad my xtx still smokes it.
Alatalo
- Jan 11, 2005
Any weight numbers...?nate007 said:Our initial mock-up will be shipped to teh factory later this week, and I expect to have a system ready to test fit and post pictures of in approximately 45 days?
In my opinion, at least as interesting as the hp numbers...
Alatalo
- Jan 11, 2005
Then my advice would be to take a closer look at aftermarket silencers for streetbikes. If you look at the high-end range with brands like Akrapovic, Arrow and Termignoni you will find much better build quality and much lighter silencers than any of the current FX Nytro specific slip-ons.00-NUKE said:I'm looking for a slip-on.
Though, in most cases you will need the skills to be able to fabricate your own conversion pipe.
00-NUKE
FOUND ONE!
SWEET! I found a FULL Hindle system for $650.00 Through Hurricane Performance. The number is (613)925-5171. They have 2 left for anyone who's interested. Ask for David Marshal.
NsNyTro
i thought from what i read that the hindle exhaust lost torque compared to the Stock header?
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
I don't have any weight numbers just yet, and I'm honestly not shooting for a super lightweight system, but rather a system with unmatched quality, no mainenance issues, tuneable sound, and with the block off plate kit that will be included, a system that will reduce the snow build-up under the tunnel.Alatalo said:Any weight numbers...?nate007 said:Our initial mock-up will be shipped to teh factory later this week, and I expect to have a system ready to test fit and post pictures of in approximately 45 days?
I'm working hrd to get the prototype finished, and plan to offer a "group buy", so i'll get the info out as soon as I can!
shadow will jump in quickly here.....
rrxx-1
shadow44
bottlerocket said:shadow will jump in quickly here.....
I've already said my piece...that's what these forums are for...info sharing...anyone who wants info on the system is more than welcome to pm me or check out the thread that's out there..
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
