exhaust/track/shocks question
yo dude 12 said:
but when you mean tune it your talking about adding more weights and rivits?
Not sure how these ones work but i think you add or reduce weight by adding or taking out the rivets.
but im still lost on what the point of weighting the clutch...other than "tuning your clutch to be most effective"
Yes Ulmers weights have no rivets in them so it leaves you with alot of room to tune.More rivet weight =less rpm=more mph if motor will pull the higher effective gearing you create by adding wieght(rivets) the weight causes primary clutch to shift out further.There are 3 holes in the weights to place rivets.Yamaha sells the rivets and they come in different lengths and materials to really fine tune your rpms right to where you want it.None of this fine tuning is needed if pipe isnt making more power.Ulmer Kit takes care of stock issues and is a great base for minor mods.
Simple answer, changing the weights in the clutch changes the speed at which it opens and closes
Do a little googleing to learn the physics behind centrifugal force and how these clutches work.
ooo ok thanks. im buying an LRD pro series 4. talked to a guy and he runs this pipe, on a stock phazer, no air box mods, no clutching, no fuel mapping, and he says it gives it more pull, low end snap, and throttle response...gunna see what its like with this pipe and go from there
yodude,
your gonna give your edge away when ya telegraph what your doing thru your pipe,
your boys will hear ya coming and simply pull away from you, where if you were in stealth mode you could of blown right by them, well maybe not blow by them but atleast you could pass them lol
pipes are obnoxiuosnow adaysespecially on a four smoke,its a steasdy drone at a certain rpm and it gets old quick imo,
Your boys, the cops at the road block, the sleeping farmers wife....
Hopefully the resale of the pipe will cover the cost of the ticket
phaze5 said:
yodude,
hahahahahhahahaha
thats whay you dont hold it at a steady speed bro hhah and if i got the power why not make them hear it and ill pass em either way
phaze5 said:
yodude,
u know u love they way my pipe sounds...lol...n how u doing bro??????!!!!!! we got to hang b4 winter, maybe a cookout or something... :Rockon:
