GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
BRP Renegade mxz 800
Anyone else added lights? Let's see !
Sent from my SM-T705W using Tapatalk
Pstn head
That's cool !!! How did you mount them ? Those will light up the whole trail. I have them on my truck and they're bright and project far into the dark.
Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
Think I saw you in Paradise today. Lookin good sir.
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
Used a stock hole in the frame, mounted a 1x6 flat, then added a 1x1x1 angle which supports the light.That's cool !!! How did you mount them ? Those will light up the whole trail. I have them on my truck and they're bright and project far into the dark.
Wired through a small square I found in the frame.
Used a fused wiring harness with the switch mounted beside the high beam switch.
Pstn head
Thanks GlenM, I like it! Nothing like lighting up the trail at night. With those it'll light up in the bush as well. Thanks for the mounting idea.
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
You're welcome !
Also did my gf Viper using a 1"x 5"x 5" angle since the frame is different in that area.
It's much sturdier than mine. Going to double the flat bar on mine, that should resolve the vibration issue. Anxious to try them out. I'll post back once I try them out!
Byam
This is the best price value part i ever bought..... 2 spot shipped to my door for 45$monopoly money
Soupy
- Jan 10, 2017
- West Michigan
Does it cover the intercooler?
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
Byam, thought you had spots on each side like mine !
Nice though, must shoot off lots of light
gdk9382
- Sep 29, 2014
- Bristol Wi.
- 17 LTX SE sidewinder, 4 wheel kit, Curve XS Skis w/leading Edge,Aux LED front light kit, 05 Rage, 98 xtc600, Past models owned 96 XT600, 94 vmax600, 91 Exciter, 87 Exciter, 80 SS440, 78 ET250
I installed the same type they are great for seeing into the corners. Takes a few stops at night to adjust just to your needs.Anyone else added lights? Let's see !
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
Can you post pics of your installation ?I installed the same type they are great for seeing into the corners. Takes a few stops at night to adjust just to your needs.
gdk9382
- Sep 29, 2014
- Bristol Wi.
I will try to get a good pic of it this weekend. I had bought the whole kit from Alpha Power sports "Sidewinder Plug And Play LED Trail Lights". But i tried to see if they have a good pic on line but i see they are no longer in business. When i bought the kit it had two brackets lights wire harness and a switch. I did not use the switch i found a better motorcycle one that fit better on the handlebar. The bracket went from under the front bumper and down at an angle to the same hole you attached you had attached your brackets. I had to loosen the bumper to slide it under it and put the bolt back in to hold it down.Can you post pics of your installation ?
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
Ah ok, I know that kit, no need for pics [emoji23]I will try to get a good pic of it this weekend. I had bought the whole kit from Alpha Power sports "Sidewinder Plug And Play LED Trail Lights". But i tried to see if they have a good pic on line but i see they are no longer in business. When i bought the kit it had two brackets lights wire harness and a switch. I did not use the switch i found a better motorcycle one that fit better on the handlebar. The bracket went from under the front bumper and down at an angle to the same hole you attached you had attached your brackets. I had to loosen the bumper to slide it under it and put the bolt back in to hold it down.
