GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
I was just about to put the sled back in the trailer; all waxed and everything after some serious summer projects.... I have two flange bolts, M6, 16mm long left over... Anyone have any ideas as to what I forgot to put back together? I just went through the parts diagrams and the only place I see anything like them are in the Frame 1 diagram. There are 8 of them there, so I don't think that's it.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
Here's what I worked on if it helps narrow down where these may have come from....
Carbides |
Primary Clutch rebuild - add Thunder products rollers, clean and inspect |
Secondary clutch cleaning |
Belly pan protector installed |
Rivnut both Belly pans |
Oil Change |
Chaincase oil change |
Chaincase replace shift forks |
Chaincase replace top gear |
Chaincase weld chain tensioner |
Lube skid Clean oil separator |
Remove skid for replacing sliders, rebuilding shocks |
Replace Driveshaft with 2.52 10 tooth |
Replace track with Ice Attack 144" |
Add BOP driveshaft saver |
Replace driveshaft bearing (brake side) |
Grease jackshaft bearing (brake side) |
Add BOP MPS kit |
Replace Brake fluid |
Repack all bogie wheels |
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
They look to me like they are belt deflection bolts on backside of secondary. There should be three of them.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
Thanks Travis. I took those out a while back when I added a belt adjuster, so it can't be those.They look to me like they are belt deflection bolts on backside of secondary. There should be three of them.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Is the end machined flat on the bolts? They are a specialty bolt and not used anywhere else on sled. I just measure one and they are 16mm long like you state.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
Winner, winner, chicken dinner!
Must not be from my projects this summer. They must have fallen out of my storage bag where I had been keeping them in case I needed to revert back to manual belt adjustment. Travis you are a lifesaver!
Rerhardt
Wow, you did almost everything that I did to my 2015 viper, my question is about the jackshaft bearing on the secondary clutch side ... there is a small c- clip on the Shaft but also a groove in the mount that holds the bearing, my sled did not have a retaining ring in it, did yours???? Will I harm anything by placing one in there???? Hope Travis sees this and any others that can respond.. I placed a snap ring there I belive it was 63mm
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
No, mine only had c-clip on the shaft, that's all I put back. I can't comment on the effect of adding another retaining clip on the bearing mount; I'm interested in hearing other's replies as well. Thanks!.... my question is about the jackshaft bearing on the secondary clutch side ... there is a small c- clip on the Shaft but also a groove in the mount that holds the bearing, my sled did not have a retaining ring in it, did yours????
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
From what I've gathered Cat models with team clutches use the large snap ring and yamaha models omit it since they have the small snap ring on jackshaft. Cat jackshaft does not have the small snap ring. Yamaha was going for weight savings!Wow, you did almost everything that I did to my 2015 viper, my question is about the jackshaft bearing on the secondary clutch side ... there is a small c- clip on the Shaft but also a groove in the mount that holds the bearing, my sled did not have a retaining ring in it, did yours???? Will I harm anything by placing one in there???? Hope Travis sees this and any others that can respond.. I placed a snap ring there I belive it was 63mm
Rerhardt
Thank you for the reply Travis, you are a world of knowledge...From what I've gathered Cat models with team clutches use the large snap ring and yamaha models omit it since they have the small snap ring on jackshaft. Cat jackshaft does not have the small snap ring. Yamaha was going for weight savings!
